Pauls Web Site
Date:  5-6-2017
Number of Hours:  12.00
Manual Reference:  W02
Brief Description:  Updrilling wing mounting blocks to 3/8"
I decided to updrill my spars outside of the plane using a borrowed 3/8" double margin non-cutting piloted drill bit. The drill bit made it practically impossible to mess this up. The pilot emerged on the other side of the spars perfectly centered in the 1/4" hole that it followed.
This way, when the wings are installed, I can drill the vertical wing attagh anges by using a 3/8"OD -1/4"ID drill bushing, and a longer 1/4" drill bit, then updrill them to 3/8" with either the double margin bit, or a longer 3/8 drill bit.
Wings clamped togeter
Special Drill bit working great
Non-Cutting 1/4
Non-Cutting 1/4" pilot emerges
