I made the initial doubler plate that will mount to inboard on bottom wing skin to support the GAP26 Pitot/AOA. I have to make another one which will have a little bit longer tab to mount under the spar. This will be sure to make the doubler plate flush with the ribs and skins will match up perfectly once riveted in place.
Once I completed this I saw that Spruce sells a pitot mount but ohh well I have it already done. I saved myself $75 wooohooooooo!
sorry about the lighting but clecoed in place on spar
