John's RV10 Project Build
RV10
Completed Outboard Leading Edge Riveting!!!!!!
Finally completed the riveting on the OB skin assemblies. RIght side went much faster.
Once riveting was completed I went over each shop head with guage to verify rivets being fully set.
No dings and I am very satisfied with results.
I have to wire the stall warning system before riveting left side.
Tonight is my EAA chapter meeting so I must stop for now. Perhaps when I get back I will work on the stall warning system.
both sides fully riveted
completed assemblies
close up of right bottom side
RV10 Home
503
Aileron
Aileron Bellcrack
Bottom Wing Skins
ER fuel tanks
25
84
Flaps
Fuel Drain Flange
Fuel Level Sender
Fuel Tank Attach
Fuel Tank Fittings
Fuel Tank Leak Test
Fuel Tank Skin
Fuel Tank Vent
Fuel Vent Lines
Fuselage Bulkheads
IB Fuel Level Sender
LE Attatch to Spar
Locking Fuel Caps
OB Fuel Tank Rib
Stall Warning System
Vertical Stabilizer
wing conduit
Wing LE Spar
Wing leading edge sp
Wing OB Leading Edge
Wing Outboard Leadin
Wing Spar
Wing Spar ER tank
Wing Spar ER tank Al
Wing Spar Nutplates
Wing Top Skin
Wing Wiring
