Attention to detail, I swear takes 3 times as long for each task BUT saves me from work later. Each fuel fitting got the same treatment as the rest of the fuel system, (Delrin Seals and permatex thread sealant). Each rubber fuel line hose was lathered in oil, cut to length and clamped in place using high quality Breeze clamps. I'll tell you though, some of the fuel line was REALLY tough to push onto the fittings due to the fitting design. Sharp stainless steel hardware combined with heavy loads meant 3 band aids in 1 job! Nothing like blood on the cockpit floor. Finally everything was zip tied with SS zips (Jury is out on these) and the thigh support was installed for good. Easy access to the pumps and filters for work down the road.
