Building Integrity
Date:  4-14-2014
Number of Hours:  0.25
Manual Reference:  ch 10
Brief Description:  Hmmmmmm.......
So there's a huge mystery here that haunts me. I remember a notice that went out that there was a rogue batch of canard lift tabs that got shipped as T0 aluminum and not T3 and are DEADLY. I found the original receipt from Brock that showed these tabs as NC-CLT which matches the deadly part #, BUT doesn't really mean that these exact tabs were part of that batch. Without some kind of "test" I'm guessing I wouldn't know if they are bad or not. One of the traits of the bad tabs is that they were mailed with a BLANK hole on top. I could assume that these are fine judging by the precision of the hole being centered where they are but this is a guess. Another mystery here is that the NEW Lift tabs from Cozy Girls are larger in width. This difference is size puts another wrench in the mix. All this to be said that I've contacted the Cozy Girls and if I can't get a confident response or way to test these tabs then it means doing surgery on the canard. A job said to be pretty easy and may very well be worth the piece of mind... More Later
interesting
interesting
