Once again, I'm amazed at the time it takes to accomplish the small tasks. So here they were.
1. Apply "EXPERIMENTAL" sticker outside fuselage 2. Clean and Scotchbrite canopy latches and install all new O-Rings with lube. 3. Install Avionics hatch cover with weather stripping applied 4. Install nose hatch with weather stripping applied 5. Clean and install pitot tube 6. Clean out and re-connect static port 7. Final interior paint touch ups 8. Full interior cleanup 9. Install seat cusions and hook up heated seat elements 10. Adjust VSI limits on G3X from 2,000ft. per min. up to 3,000ft. per min :) :) :) 11. Smack forehead with hand when seeing that Princeton Electronics returned my fuel probe boxes WITHOUT the plugs installed....Grrrrrr!
