So I used the DA to clean up the Carbon Job and found that I actually like the contours I made and can see that after adding micro, the Lines will be really nice. Plus, the Clearance to the Oil cooler is good so no heat issues should ever show up. I'll take it :) Now to add 3 more plies of Carbon on the Inside of the new lip and Micro to the exterior. Coming right along...
