Boy I'm surprized how well the contouring came out on the repair areas. I laid down a few coats with a roller and cant wait to block sand em. I intentionally did NOT add filler to the areas needing it because I want to sand it down along with the primer here that is used as a guide coat. If all goes well I may only need 1 more round of primer before wet sanding. The roller makes it really nice but there is orange peel using this method. But then, orange peel has it's advantages with a guide coat as it's much easier to see when you need to stop sanding. (peel is gone.) Tomorrow the block and paper come out :)
