Eh not so hot. I intend on finding a solution for the drafty air that comes in and freezes my thighs in flight, however todays work didn't work. I was able to make a template for a foam plug idea I had however the gap between the elevator and fuse is too tight to get anything inside there without removing the canard. I most likely will decide on FINAL paint/wrap/primer before I cover this topic again. the foam I made would bunch up and not make a seal around the perimeter as hoped. I KNOW there IS a solution but this one is on hold...and summer and San Antonio is coming!
