Took quite a while to remove the first set of 6 injectors then, install the "clean" set. I've done this 3 times and I really don't want to do it again. Especially when it takes a good 30 minutes to install the plenums. Glad it's good to go for tomorrow's flight testing. I also confirmed that my new rudder pulley brackets are going to work wonderfully. I'll be installing the pulleys on the brackets if I wake up to cloud cover. :) Excited to try out the new cooler and lower cowling mod!
