Removing as much filler as I did, I was a little worried about the contour matching the fuselage. My Friend and Ez owner, Dave Shultz, was over looking at the project and I put him in the cockpit to let him check things out. I couldn't resist and I put the canopy on to let him see the difference in size. While it was on I checked the contour and saw that it had actually got better! I decided to block it down tonight and bring it to the point where it is almost ready for the final coats of primer. I still have to lay down the final tape line and sand the filler down to plexiglass below that point, but other than that, she's ready.... minus a couple pin holes ;)
