After advise from other experienced builders I've concluded that my original location for the Transponder antenna was poor for several reasons. Either way I've re-located it to a MUCH safer and more accurate position on the outside of the righrt strake. The connector will be covered in heat shrink after install to protect it from any water that may find its way into this area later.
