I went to attach the canopy to the hinge and found that I didn't plug the anchor nuts prior to laying up the hardpoint flox and it dried Inside the threads. DOH!! I spent the next hour drilling it out and basically re-tapping the threads. Can't believe I forgot that. Moving on.... I finally bolted it up and checked the 45 degrees of movement and I am very pleased with the results. The MOST telling point will be how rigid the canopy frame is when all the Carbon Layups are completed. More to come....
