This will be a scratching my head project for sure. I've had to remove all the old manual hardware and will need to relocate the brackets accordingly with no directions to follow other than common sense. I've also decided to use Tinnerman washers and flat head screws on the entire outside surface of the aircraft. The screws shown will be replaced with stainless steel ones as flight hardware.
