Jims RV-8
Date:  12-17-2020
Brief Description:  Right wing tank wiring, grommet edging
I measured, cut, stripped, labeled, and crimped the connections on the positive and negative fuel sender wires for the right tank. The Van's diagram shows 18AWG, so that's what I went with. I also did a test fit on the rubber car door edge protector I bought. It has a peel and stick side with glue and seems very secure. This will protect the rear seat vent tubing (scat) as it goes thru the wing rib lightening holes. I finished off the night by cleaning up the remaining part of the second workbench. I now have plenty of room to lay the entire wing across the two work surfaces.
wires connected and heat shrunk together
grommets in place - test
benchs clean
benchs clean
