Brief Description: Move wire exit and cleanup wing rivet area
I was thinking about all the things that would be harder to do once I have the skins riveted to the wings and I decided to make another wire exit hole in the next bay outside of where the bellcrank and autopilot servo will be. I still have the original hole to use if I want it, but this way the wiring can come in from the outside bay down along the main spar and into the a/p servo if needed.
I also cleaned the first workbench and most of the second - in preparation for wing rivets
