Jims RV-8
Date: 4-10-2022
Number of Hours: 3.10
Brief Description: Right-Side Panel Wiring
I spent the most time laying out the plan of wiring the right-side panel. The right-side panel will be riveted in place, and while the center panel will be removable, the right-side panel will not, and there are many common wires between the two panels that will need service loops.
I have a good grasp of how the Nuckolls Z-12 electrical diagram functions and relates to the switches, bus bars, and boxes, but running the wiring to make all those functions happen takes more understanding. So, I sketched it out into a picture and then started working on wiring it. I didn't get very far before I stumbled upon the 2-10 vs. P-Mag switch idiosyncracies. They are both DPDT (Double Pole, Double Throw) switches, but the two diagrams are different. One view is looking thru the front of the (2-10 switch) from a front-facing view to see the terminals in the back, while the other (P-Mag switch) is looking at a rear-facing view of the terminals. The P-Mag switch has numbers on the terminals, so I have to trust that those are correct.
Anyway, I made some progress as I cut and drilled the shared bus bar between the two alternator CBs. I will power them separately, but if one power supply is faulty, I have the other supply to fall back on. I also put a section of heat shrink tubing around the two inner posts of the engine start button as they are not needed in my application. Saw that trick on Bob's log.
shared bar - Alternator power
heat shrink the un-needed inner posts
right side panel inching along
