I continued with the wiring of the right-side panel, mainly working on getting the master contactor wire back to the battery contactor in the aft baggage compartment fished up thru the conduit to the master switch. That was a bit of a chore as I have a few thicker buss wires and starter wires running thru that conduit. I would have liked to run it in that same conduit, but it was too long a run to get the wire or the fish wire up thru that conduit. I tried multiple times from both directions, but it was not going to work. I thought I had left a fish wire in that conduit, but I did not. So, I ran the master contactor wire through the secondary/spare/empty conduit I have going back there. I still have two other conduits running under the cockpit, so I have plenty of options for additional wires. A rather frustrating session, but I did get the master contactor wire run.
