RV-6A - GBC
Date:  5-13-2006
Number of Hours:  0.00
Brief Description:  Prelim inspection cont'd
The aft fuse skin was marked as damaged, but there was a replacement skin. The right side of the fuselage was impossible to inspect up close but nothing apparent to be concerned.
The ailerons, again, completed as part of THIS QB were still wrapped from the factory. The skin appearance was pristine. No dents, corrosion, or concerns with these.
Wing & fuse skins
Wing & fuse skins
Aft fuselage
Aft fuselage
Ailerons
Ailerons
