Decided to revisit the fuselage for awhile and take a break from the wings.
Located the proper bulkhead and fasteners, drilled to spec and temporarily attached the anchors and harness cables. The fasteners would interfere with the top skin rivet process, so they are temporary for now.
Need to double check the spec for the cable fastener. It's sometimes a little frustrating to find the correct drawing for the anchor but no mention is made of the cable. Apparently, it will be spec'ed on another drawing but the cross-ref would be a time saver.
