RV-6A - GBC
Date:  8-15-2006
Number of Hours:  0.00
Manual Reference:  Dwg #36
Brief Description:  Additional photos - F-675 aft top skin
Photo #1 - note slight 'curve/twist' forward in the flange at the left center of the photo. However, the inner flange and web are secure and consistent with surface 'shape' of the skin.
Photo #2 - note the aft 'sweep' of the rivet line from top to bottom indicating that the flange of the F-608 bulkhead also follows this line. At first this seems 'crooked' but in consistent with the shape of the trim line required for the F-674 fwd top skin, specified on Dwg #36. Conclusion - NOT a problem, just seems odd.
Photo #3 - during the back drilling of the F-675 aft top skin, this area had a little 'oil canning' (flexing) but seems firm and acceptable after all clecoes inserted and skin pulled tight.
F-607 bulkhead slight twist
F-608 rivet line - note curve
Skin tension - tested
