Cabin heat diverter is no longer being used with RV-7 type center console, so the diverter is being attached to cover the FW heat intake which brings hot air into cabin from an exhaust pipe attached 'muff'.
In addition, because of the 90 deg angle adapter on the oil filter there is no requirement for a FW recess. A flat SS plate has been fabricated.
So this task involves final fabrication of the diverter and control cable attachments for the heater valve.
