Lots of tasks, canopy SikaFlex process only one of them. Attaching the canopy side skins to the exterior side of the plexiglass as a way to 'fix the position' of the whole canopy. Then will setup for the interior SikaFlex process in one step.
Reviewed Load Planning configuration with Ken, and discussed the eBUS operation. Modified the switch assignments for Avionics and then shifted the other assignments to the unassigned switch. Had not understodd the the eBUS operation, automatic actions.
Shortened and terminated a few more circuits, and it should be almost ready to install in the equipment bay. Need to prepare & cut the panel first.
