Lots of misc details all over the plane. Example; added split tubing to the seat harness steel cable restraints to protect the cable and where it rests on the angle supports for the SV ADAHRS.
Removed clecoes, skin, rear window for access to the SV Pitch Servo to torque, and safety bolts. Started removing wires from fuselage conduit to sort out the changes in the lighting wirings.
Put the last 3 CherryMax rivets in the flap brace repair task.
Tried to correlate all the wiring info for the Vertical Power, Dynon components. Switch functions, connectors, and ergonomics of operation.
