RV-6A - GBC
Date:  10-21-2014
Number of Hours:  2.50
Brief Description:  Rudder - Replacement
Cut the remaining stiffeners from the strips, prelim debur. Dimpled the new spar and clecoed to new skin. Added the bottom rib and match-drilled the components of the reinforcement plate and angle to the assembly. Match-drilled a few holes on the bottom rib for preliminary alignment. Remaining holes will await bending of the trailing edge of skin.
Cut out new stiffeners
Match-drill to new parts
Match-drill bottom rib
