Test fit the plexi, which has been sitting in the corner for months, and preparing for final stage of canopy construction. The area of the inside surface is insufficient for a GPS mount. Will have to put it in the turtle deck aft of the baggage bulkhead.
Prepare to do final assembly of the entire cockpit (canopy, rear window, and rollbar components).
Fit is identifying little adjustments and sequence of assembly. These details are not as detailed in the RV-6/6A as in later models.
