RV-6A - GBC
Date:  11-2-2010
Number of Hours:  1.00
Manual Reference:  Dwg 46
Brief Description:  F-699 floor brace
Review of plans, and pre-planning wing fitting. What's required, what needs be done, and what should be accomplished in the initial fitting.
Ran across a previously missed task - F-699 braces, referrenced on Dwg 46, and in the text. Very important for strength of floor, especially when wings are install (and A/C sits on the gear). Bolted to floor longeron and lower spar.
Ordered an F-6118 bracket to use as material to fabricate the F-699's --- called out at 063 2024-T3
Continue to research and prepare.
Future F-699 brace location
