RV-6A - GBC
RV-6A QB
Cowl - Side hinges
Drilled the Rt side hinge (top/bottom) and then drilled a few holes on the joint between top/bottom, on both Rt & Lt sides.
Limited number of holes will be used to test fit alignment and fill later if not right, or drill remaining holes if good fit.
A little more sanding on the contours of the Rt side and ended with a satisfactory rough fit.
Rt side contour
Rt ring contour
RV-6A QB Home
3573
222
440
140
392
Finishing Kit
165
457
156
864
Gear
109
QuickBuild RV-6A Kit
455
Workshop
