Brief Description: Back drilled all side skins to #30 and joggled L a
This morning I back drilled all the remaining holes from #40 to their actual side of #30 and then removed each of the L angle supports and joggled the bottom end so that it follows the contour of the the bottom longerons.
Both side skins drilled out to #40 and L angles joggled to fit longerons
