Brief Description: Back drilling right rear side skin
It's cold and wet tonight and the traffic coming home from work was a nightmare, it took a lot of effort to spend quality time in the garage tonight, I nearly convinced myself to have another night off, but the old addage of, if you do even a little bit each day it will eventually get done, convinced me to drill lots of holes. Did I mention that the fuse had more holes then the wing...this is not really evident looking at the side shots because I have not clecoed every third hole.
Rear fuse, initially just drilled every third hole
Front view
All holes back drilled in lower longerons and L angles
