Brief Description: Right wing upside down and being leveled
Once the bench was clean I turned the wing upside down and proceeded to level it font and rear, along with setting the required 81 degree angle on the front spar. This took a long time, every time you move one end the other end is also affected, however after lots of fiddling and placing shims under the wooden blocks I got it set up correctly.
Leveling the main spar and settign the correct angle of 81 degrees
Another shot, the board with the 81 degree cutout is upside down to set this angle
Shot of the rear spar showing it has also been leveled
