Brief Description: Nose ribs and aileron bell crank
I started marking out the cuts required on the nose ribs so that they fit down into the spar properly, I decided while I was doing this that I might as well do the left nose ribs at the same time, so I labeled and marked all 6 ribs and did the requried cut outs at the same time. I also marked out the bell crank supports for the right wing, did a rough cut with the hack saw and then smoothed down the edges on my small bench linisher. I still need to do the left had supports using the first ones as a template, so that I don't need to re-measure again (that assumes of course that I got these correct).
Nose ribs with cutout for spar and holes drilled for fuel line
