Brief Description: Flaps complete, marking out the Left aileron skin
It's finially Friday again, end of along week, I decided to try and get as much done as possible before brain fade set in. I finished the riveting of the ramaining flap assembly including the attachment of the hinge. I now need to find somewhere safe to keep the flaps until I attach the flaps and ailerons to the wing. Started marking out the required cuts on the out board side of the left aileron, also marked out the rivet pitch and the location of the ribs, managed to do both sides before calling it quits, I think before I cut or drill anything, I am going to re-measure just to be sure. Also need to double check that I am not building either two left or two right ailerons, I imagine this would be very easy to do, given that the skins are identical.
In-board side of left and right flap assemblies completed
Out-board side of left and right flap assemblies completed
Marking up the left flap with the required cut lines and rivet pitch
