Brief Description: Stuck cork unto the outside of fuel tank
Besides sticking cork directly onto what I think are the main contact areas, I also stuck some cork onto the two end ribs as recommended in the instructions. The plans show 3 layers, I tried two and found that the tank did not fit, so off came one layer, what a waste, lesson learned try first add more if it does not work.
