Brief Description: Disassemble Aileron, deburr and dimple
Disassembled the right aileron and deburred the skins and the ribs. The hinge is to thick to dimple, so I set the drill press up and counter sunk the holes in the hinge. I finished dimpling the top skin of the aileron and ribs, so there is only the bottom skin left to do. I will have to dimple the bottom skin by hand because it will not fit into the dimpling press, once this is done I can apply the corrosion inhibitor and reassemble.
