Brief Description: Installed Ray Allen flap sensor
Installed the Ray Allen flap sensor behind the flap actuator arm. Connected it to a Ray Allen flap position gauge to help with the positioning of the servo arm. Drilled holes in the flap actuator arm for the flap servo rod. Very much trial and error to get the right amount of travel. Right now it indicates correctly with flaps extended but slightly off with flaps up. Will work on it again tomorrow.
