Used stainless 3/4 inch 6-32 screws and rubber standoffs to mount the ExBus panel to the avionics shelf. Ran a cable with three 22 ga wires to where the flap servo will mount. Also ran the Skytek fuel sensor cable to the front through the torque tube tunnel. Drilled a hole through the foot on the skytek tank and secured with a 6-32 screw and nut. Was going to clamp the fuel and return hose to the Skytek tank but ran out of small clamps. Will purchase those tomorrow.
