Attached the micro Molex connector to the aileron trim assembly. I really hate these tiny connectors and pins they are so hard to crimp properly but Vans has them in the wiring harness already so you need to cut the micro Molex connector off the factory harness if you want to change. Started working on the wing tips by trimming the flanges per plans. I used a carbide wheel in my Dremel tool an it cout the fiberglass easily and smoothly. Once cut and sanded, I got the left tip fit onto the wing and it fits really nicely with the skin butting right up to the flange in the fiberrglass. Alignment with the aileron looks good.
