Cutting the tank parts apart and deburring and adding nut plates, etc. The tank stiffeners and Z brackets and J channels need to be cut apart and deburred. The stiffeners get dimpled while the Z brackets have nut plates added. The J channel is cut to length thenmatch drilled to the tank skins. Standard mfg processes by now in the kit.
