Chris's RV-14A Site
Date:  1-5-2016
Number of Hours:  4.00
Brief Description:  Buid wing cart and leading edge holders
Woodworking day today. Built cart for the wings and the holding stands for the leading edge construction. The cart is from 2x4s and some 3/4" MDF. Design is a conglomeration of many others that I have seen in build logs plus I addded 2x4 beams to the far end above the cut out for the leading edges. This way you can sit the main spar across the ends until you attach the leading edge then remove a bolt and the beam will swing out of the way and let you sit the leading edge/wing assembly into the slot.
Leading edge holders
Removable beams
Removable beams
Wing cart
Wing cart
