Started getting some parts ready to paint so working on the tips and the joins between them and the aluminum. Using Super Fil which is just an epoxy that is pre filled with micro balloons. Goes on easily and easy to sand as far as sanding an epoxy. Next will be a coat of expoy primer then body filler to finish the seams off and have them ready for painting.
