Match drilled the bottom rudder fairing to the rudder, The flanges of the fairing are a little too narrow for my comfort after the rivet holes were drilled, so I've decided to bond in some aluminum backing strips for added strength. I then added a bunch of micro to the tail light bulge to build it up as the stock shape doesn't quite match an aluminum mounting ring that I'm using yo mount my tail light with.
