Drilled the F-1014 aft deck to the longerons and other sub-structure components (spacer, doubler, etc). Ran into a slight problem. There are a few holes that get final drilled to #12. Two of those are the holes on each end of the attach bar support angle that are common to the longerons. Anyway, these holes are right next to the HS attach bars which I can only get at using an extended bit because the drill itself hits the bar which would make a slanted hole. The problem is I don't have a #12 extended bit. What pisses me off is I just ordered a #17 and #28 from the Yard Store. I'm going to call them in the morning to see if I can get the #12 added since I'm already paying shipping.
