TODD'S WEB SITE
Date:  1-17-2010
Number of Hours:  6.00
Manual Reference:  Sec 13 - Spars
Brief Description:  Countersinking rivet holes
Ran a #40 through all the spar flange holes that had not already been match drilled. Then dialed in a #40 pilot countersink and began CSK’ing all of the nutplate rivet attach holes. This took a couple of nights to get done as there’s a huge number of CSKs that have to be made—I thought this task would never end. After the CSKs were done, I went back and dabbed a blob of Sanchem into each CSK with a small paint brush (the kind you would paint water colors or a model airplane with) for corrosion protection. Figured if the Sanchem worked (I wasn’t doing any of the prep steps like I normally would) them maybe I wouldn’t prime the holes as called for in the plans. The Sanchem worked just fine.
Rivet hole CSKs
Rivet hole CSKs
More CSKs
More CSKs
Action shot of me making the CSKs
