Arts Web Site
Date:  12-24-2022
Number of Hours:  3.00
Brief Description:  Dimple LH Splice Strip
I read about cracking problems when you dimple #8 screw holes on VAF. This is a part I really don't want to have to buy again so I spent some time deburring not only the hole edge, but running little strips of maroon ScotchBright through the holes to polish the bearing surface. It seemed to have worked as I didn't have any cracked dimples.
Sprayed some SEM green primer on both the splice strip and the mating surface of the stall warning switch plate. After the primer dried I installed all of the nutplates.
Finally I reassembled the rib back in place with the splice strip so that it's ready for riveting.
Primed both sides of the dimpled splice strip
Stall warning switch ready to install after the rib is riveted to the skin
Rib and splice strip back in place for riveting
