Arts Web Site
Date:  12-23-2022
Number of Hours:  1.00
Brief Description:  Prime and Assemble Stall Warning Micro Switch
I can't proceed with the riveting without someone to buck, so I moved ahead in the plans to assemble the stall warning switch. Opened up two holes to #30 and countersunk the switch mounting plate for screws.
Switch will be installed on the LH OB LE inboard rib after riveting.
Update 25 December: There is a wire that is installed on the microswitch that terminates with a ring terminal on the lower hole in the picture below. I'm not sure if I need it, but just in case I wiped off the primer around the hole with acetone so the washer/screw will have a ground path.
Switch assembled and ready for installation after final riveting
