Roberts Web Site
Date:  6-25-2010
Number of Hours:  4.00
Brief Description:  control push rods
Clamped the ailerons and flaps in neutral position. Cut the aileron's pushrods to proper lengh,
installed the inserts and the bearing connectors. Connect to PF-196.
Cut the flaps pushrods and join them with the connecting tube that I got with the flap option.
I've decided to go with an electric flap motor. No handle with wire, pulleys and spring.
I bought a linear 12V motor with 4'' stroke from ''Princess Auto'' ((http://www.princessauto.com/))
I also bought a flap controller from Aircraft Spruce. I got the idea from Sylvain Papillon, who installed the same motor with a different controller on his L160 and it seems to work well.
aileron pushrod connection
flap pushrod connection
linear motor and flap controller
