Christophers Web Site
Date:  11-29-2016
Number of Hours:  18.00
Brief Description:  firewall/electronics
10/30 3.5
-Leveled fuselage and lined up engine mount about 15 times.
-Drilled holes for mount
-installed fiberfrax and rough cut stainless steel
11/1 1 fit and drilled stainless steel for engine mount
11/3 1 installed engine
11/5 2 cleaned up shop and started fitting cowling to figure it out
11/6 1.5
-set electrical/fuel components around to figure out locations
-drilled hole for fuel line in firewall
-mounted ignition coils and msd switch
11/10 1 mounted battery pass through and master solenoid
11/24 4 made some battery wires. Mounted oil cooler, oil catch can, voltage regulator, fuel pumps and gascolater.
11/25 1 installed radio in panel.
11/26 2 drilled and installed control knows, and switches in panel
11/27 1 ran some wiring behind panel
