3/9 1 -installed fuel vent 3/10 2.5 - fiberglassed right fuel tank access holes -cut out panel hole for transponder -started working on transponder tray mount 3/11 3 -capacity check wing tank with gas. 16 gallons and no leaks!!!!!!! -finished transponder mount -mounted and wired iFly 740b 3/13 1.5 -wired current sensor -started gluing foam on right wing 3/14 1.5 -sanded nose ribs to contour -Made transponder antenna ground plane 3/16 2 -more wing sanding and adding panels 3/17 1 More sanding 3/18 2 And more sanding 3/19 1 More leading edge sanding Mounted transponder antennas 3/20 1.5 -glued in trailing edge foam and sanded more 3/21 2 Finished trailing edge 3/22 1.5 Filled in gaps with foam and sanded Started cutting fiberglass 3/24 1 wired transponder gps 3/25 2 glassed main spar back 3/26 1 Wiring 3/27 2 More EMS wiring Drilled egt sensors
