5/28 2 attempted lower wing root fillet. Will do it again later. 5/29 2 cut wing free and trimmed trailing edge 5/30 3 -Flipped fuselage -Worked on wing spars -Made trailing edge fixes on left wing 5/31 3.5 Made airfoil tip template Set washout and drilled wafs Tapered spars 6/1 3 Made spar extentions Glassed spars for fuel tank 6/2 2 Glued root and tip templates
